Pretty dissapointed
Well,I got the right rings for my SC..... Now if I would have known that they were oversized pistons, then I would of had the right ones the first time. Heres the thing, I got the rings on, put the pistons in, torqued them. Put the oil pan on, torqued it. Put the head on, torqued it. Put the push rods in..... Put the rocker arms on... Torqued it.... Lubed the springs, etc. up. Set the valve clearance. Put the valve cover on, one turn past finger tight.. now I had everything as far as the engine goes togeather, except the magneto.... Put the No. 1 piston at TDC before we put the head on too..... Now the dissapointing part.... Put the gear lube in.... Put some oil in the pan..... Put some ANTIFREEZE in... Then it started to leak.... another PROBLEM.. It was leaking from the water jacket-where the pump bolts to the block, so we had to tear allthe front end apart..... Radiator, and the grille, and the water pump, and the cast iron tube it bolts to... Now, the gasket was shot-about a 1/2" missing out of it..... So here's what we did. Took some HIGH TEMP gasket MAKER, and put it around the water jacket, and we took the water pump off, and put gasket maker on that too- mine as well since we got it off.. Then we put it back togeather after an hour-which is when it starts to harden... then we put it back on the engine, and then we let it sit loosely overnight, becasue it takes 24 hours to FULLY cure. So we tightened it all the way this morning. The bad part is we couldn't put any fluids in it because it had not fully cured. So, now I have to wait 2 more weeks to go back up to the lake home.... And then put the rest of the fluids in it. I also need a wiring diagram for the on/off switch to the magneto, or just a really simple, yet good explanation. And I also have a Marvel-Schebler carb on it. How many turns should I put it out to start with on the adjustment... It only has one needle screw on it. I have some pictures,but not of how far I am now.. I will get a scanner pretty soon, and post some. I would like to get a video camera and record the first time it is being started so I can watch it over and over!!!! But I don't have a video camera.. Maybe I can find a used one-ish, but as long as it works good... Well I need some replies so I can figure this stuff out so.....REPLY!!! Thanks everyone for taking your time to help me over the past 1 1/2 years!!! Thanks a LOT!!!! This wouldn't have been possible if it weren't for this site... Isn't it wierd that an EARLY SC had an overbored engine, which was only availiable in like 1950?? I know it isn't that uncommon because someone can just overbore it themselves... Did you also know that if ANY of your tractors are 6 volt, then you should have a posotive battery cable at least as big as 1 gauge!!! There's a tip if your tractor isn't starting and you think that it's your electrical.... From a guy at the local NAPA.
