vac
tompepper
09-20-2006 10:51:29
i just bought a vac.i need to know where to find the serial #.i also need to know where the hyd resivor is located and what type of hyd oil to use
Paul f
09-20-2006 14:32:42
 Re: vac in reply to tompepper, 09-20-2006 10:51:29
Is you pump under the belt pulley or on the front of the engine? That will help ID year if you don't have a data plate. The torque tube is the reservoir Filler is on left side just ahead of clutch pedal. Originally called for 20w (or 10 depending on temp...I and others just use tractor hydrulic fluid.
tompepper
09-20-2006 16:03:06
 Re: vac in reply to Paul f, 09-20-2006 14:32:42
the pump is what appears to be a geardrive pump mounted on the right sside front of the motor.the big tube from the pump comes out of the top of the housing between the bell housing and transmission and the small one goes from the pump back to the 3 point control.
Paul f
09-21-2006 07:41:12
 Re: vac in reply to tompepper, 09-20-2006 16:03:06
The area between teh bell housing and teh tranny is the torque tube. Look for fill cap on just ahead of the clutch pedal
Lewie Hoskinson
09-20-2006 11:58:04
If it's an older one like mine [47] it should be on the panel above the steering shaft in clear view from the seat.
