What color and paint codes
Bill64
09-15-2006 15:23:12
I have a case model 310 utility. What is the name and color code for the sheet metal on this tractor? Is it desert sunset or power white? Are there aftermarket codes?
Thanks
Bill
El Toro
09-28-2006 07:54:28
 Re: What color and paint codes in reply to Bill64, 09-15-2006 15:23:12
Hi Bill, Here's a web site for PPG's tractor paint codes. Hal
PS: I'm usually on the Farmall forum. Doesn't some Case tractors have this firing order 1-4-3-2?
I used PPG's single stage Omni Acrylic Urethane
on a Troy Bilt tiller using IH paint code. Looks like new.
http://www.worldpath.net/~thompson/misc/PPG%20Tractor%20Colors.htm
Bill64
09-28-2006 14:56:19
 Re: What color and paint codes in reply to El Toro, 09-28-2006 07:54:28
El Toro,
Thanhs for the PPG Paint link. Just what I was looking for.
Thanks again,
Bill
Lineman
09-16-2006 11:52:28
 Re: Desert Sunset Omni Base Coat Formula in reply to Bill64, 09-15-2006 15:23:12
I fould an old quart can of Desert Sunset on the shelf at my local Case dealer and put some on a piece of metal, took it to the ppg dealer and had them use there color matching equipment on it yesterday. I have the formula for a half gallon of Omni base coat on the back of my label. E-mail me if you want the formula.
Bill 64
09-17-2006 10:19:33
 Re: Desert Sunset Omni Base Coat Formula in reply to Lineman, 09-16-2006 11:52:28
Lineman,
Tried to E-mail you about the paint codes but got rejected. Any codes for desert sunset or flambeau red would be appreciated. All you other Case guys out there feel free to chime in.
Thanks
Bill
Lineman
09-17-2006 18:52:54
 Re: Desert Sunset Omni Base Coat Formula in reply to Bill 64, 09-17-2006 10:19:33
Bill, I was going to e-mail you the code but when you hit the send e-mail button it goes to some other post, the site must be having a problem.
Here is what the tag on the back of my label says for 2 quarts of omni au base coat:
OMNI AU (MBC LEADED) Custom Formula 904431
2 U.S. Quarts
Revision Date 9/16/2006
Main Layer
SKU / DESC / C UM / INC
M119 / WHITE / 783.7 / 783.7
M152 / LF YELLOW / 1050.0 / 266.3
M153 / RS YELL LF / 1118.9 / 68.9
M106 / RED / 1260.2 / 141.3
M150 / CLEAR / 2297.7 / 1037.5
The forward slash is only to show the seperate fields, not actually on the label, post wouldn't leave them lined up. There is no space between the C, and the UM, had to do that so the site filter would let me post the message.
This is color matched to a can of Case IH enamel, Case Desert Sunset B17651
Any PPG dealer that mixes Omni paint sould be able to use this. Hope it help anyone that needs it.
Take care,
Lineman
630crazy
09-16-2006 11:05:09
Desert Sunset would be my guess...Power white didn't come out until the seventies.
