VAC WON'T START
JON
08-16-2000 04:09:30
I REPLACED THE DISTRIBUTER CAP ROTAR AND WIRES WHICH NEEDED IT I ALSO REPLACED THE COIL IT DIDN'T WANT TO FIRE THAT I COULD TELL
IT ALWAYS FIRED RIGHT OFF
I HADN'T RUN IT IN ABOUT A MONTH AND THEN NOTHING
THE ONLY THING DIFFENRNT IS THAT I FORGOT TO PUT THE CAN ON THE MUFFLER AND I GOT ONE RAIN FALL INTO IT
THE CARB IS GETTING PLENTY OF GAS THAT IT IS LEAKING OUT BUT THE SPARK PLUGS NEVER GET WET
steve
08-16-2000 10:09:00
 Re: VAC WON'T START in reply to JON, 08-16-2000 04:09:30
i am not an expert, but if you are in a hurry, here are a couple of things to check.
pull a plug, ground the base with the wire on it and see if it is firing across the gap.
if not try pulling the cap and see if you have a bright spark across the points.
have you tried filing the points? that usually is what gets corroded first.
turn in your carb jets to seat keeping track of number of turns and then take them out and see if they have rust on them if not put them back in to seat and then back them out to original position
sometimes this will let crud out of the jet.
if they are nasty you may have to dismantle the carb and clean it up.
my vac is bad about condensating water into the tank. check the bowl for color of gas, if it is layered or clear, probably full of water and it will act like it is out of gas as the carb can't vaporize the water.
