Case VAC 12v question-replacing coil
sodbuster
08-05-2000 13:14:27
I recently purchased a 1949 case vac and it has been converted to a 12volt. Lately the tractor will run a while and just quit. A guy at the tractor store told me to replace the coil. I picked up the coil and read that it says 6volt on the side. Will this work? Should I try to install it? Any other suggestions for my problem? Thanks.
Tom Harrower
08-05-2000 14:13:34
 Re: Case VAC 12v question-replacing coil in reply to sodbuster, 08-05-2000 13:14:27
You can use the original 6 volt coil but, you will need to use a resistor in line if your tractor is converted to 12 volts. A resistor that will do the job is a NAPA part # ICR-13. Or you may choose to use a 12 volt coil, without an external resistor, such as NAPA coil part #IC-14. There is an article in the article archives you can find in the index at the far left of this page, the article it titled" Recomendations For 12 Volt Conversions" it contains very clear instructions on choosing parts, and making the connections on your 12 volt system. Also, check your E mail, I am sending you a diagram that was passed along to me when I was doing this conversion on my '53 VAC with a magneto Ignition. It shows the system using a resistor in the ignition circuit when using a 6 volt coil. Please post again and let us know how it goes. Tom
sodbuster
08-06-2000 20:20:12
 Re: Re: Case VAC 12v question-replacing coil in reply to Tom Harrower, 08-05-2000 14:13:34
I tried your suggestions and found your help very useful. First of all, Napa auto parts is much better than going through a Case dealer. The tractor is running better and I notice it running smoother because I replaced the wires, distributer and coil all at the same time.
The tractor did quit a few times as I ran it for 3-4 hours today. The battery later died on me. Maybe the alternator is shot? Would that make the tractor just stall out as I'm running it?
Any more suggestions?
Thanks again, every bit helps.
Mark
