HERE'S ANOTHER ONE FOR YOU- FITTING AN EAGLE HITCH ROCKSHAFT HOUSING OFF A 500B ONTO A 420B
Ken McWilliams
07-23-2000 18:16:06
The 420B that I have was originally a tractor/loader/backhoe tractor. Thus, no PTO or 3 point hitch.
I found all this stuff on a 500B/600B and all looked as if it would fit. I measured the rockshaft cover and all the attachment bolts and they all matched perfectly. Also, the PTO assembly mentioned in the previous posting.
After I checked everything and after removing the rockshaft housing from the donor, I placed my blank cover over the opening on the donor casing and it fit perfectly bolt-for-bolt.
Today, however, I found the problem. After preparing the surfaces and applying some ultra-blue RTV, I placed the rockshaft housing over the opening on my 420B and it wouldn't go down all the way. When I looked under it, I saw the reinforcement for the lifting cylinder resting on each bull gear. At this point I had three options: 1)Go buy the right one to fit this tractor -- but I'm too cheap and won't spend the money. 2)Put the assembly up on my Bridgeport mill and mill away the extra material -- but that will weaken the casting and may cause the casting to break under heavy load. 3) Raise the rockshaft assembly so the reinforcement will be above the bull gears.
I chose option #3. I have some 1-1/2" X 3" bar stock that's been stored under my lathe for about 15 years. I cut it to size and put it under the rockshaft housing as a "picture frame" spacer. Then, I transfer punched the bolt locations and drilled them on the Bridgeport. I'll weld them on the corners while bolted in place and then remove the "picture frame" spacer and thoroughly weld the corners before final installation.
I may have to reroute the hydraulic lines and rework the seat if it's too high, but I wanted to use what I had.
The bonus is that the "picture frame" riser now gives me a place to weld the lugs for the upper link/arm for the 3 point hitch.
I'm just too cheap, I guess. At least I'll have a functioning tractor, but not the prettiest one.
Is there another way to do it differently?
Ken McWilliams
Dayton, OH
