D series case
Rick
07-17-2000 13:26:19
I purchased an old case tractor. Could be anywhere from a 1939-1950 D series tractor. It has a hand clutch, battery mounts over the steering wheel. Dual brakes, one foot pedal on each side. It is a heavy duty tractor, the serial number was not on it(ID plate missing) I called Case and they had no idea. I have used new parts on it from our case dealer. I have converted it to a 12 volt system, new everything on it and painted it. There doesn't seem to be much market in the case tractors and much as the fords/john deer tractors. If anyone has a picture so I could tell exactly what year it is I would appreciate it. I was told it was build during the war and used by the airforce to move aircraft. It is a heavy duty wide front end tractor.
mel
07-17-2000 17:36:08
 Re: D series case in reply to Rick, 07-17-2000 13:26:19
clean the paint off the engine flange right behind the air cleaner and see if there is a serial number stamped in the block- right near the oil pressure fitting a letter and a number. Unless the military has their own number sequence subtracting 4 from the first 2 numbers of the SN should give you the year, unless it is very late in the D series, then that don't work.Good luck, the D series are great tractors.Mel
