David Brown 990 Selectamatic 3-Point Control
Sheldon Leonard
06-15-2000 15:53:20
I am in the middle of repairing a David Brown 990 Selectamatic 3-Point Control and I am running into problems. If there is anyone out there with some experience or knowledge that might help, I would definately appreciate it. Thank you!
Elmer
06-18-2000 06:36:44
 Re: Re: Re: David Brown 990 Selectamatic 3-Point Control in reply to Sheldon Leonard, 06-17-2000 20:03:29
First thing to do is go outside with that I&T and light it up. It is only good enough to get you more confused. Their is a valve in the control chest that can stick and make the links raise and stay up. It is called the latching valve and lays vertical between the hold and bypass valves. If you want a proper manual i can copy mine, or if you want to pay more i have an original extra, published by David Brown. It has a section in the Hydraulics part of the book that tells you how the system works. The system is easier to repair when you understand how everything works and why each component is there. The link rod at the quadrant could be sticking too. Oh yeah, let those mechanics laugh all they want, the stuff they are working on is no better.
