VAC CASE CARBURETOR PROBLEMS
mark
05-26-2000 10:12:52
Can anyone help with a carb problem? The tractor (1946) was running fine, until I had it on a side hill. Gas tank valve was at the low point. Then it would only run with the choke almost completely on. I took the carb apart and cleaned it, and reassambled exactly (I think). Now the tractor races wildly. I have tried adjusting the needle jets with no luck. Any Ideas? from where to where do I measure to set the float? How many turns out should I restart the jets at? (which one does what?) Thanks. (Marvle Carb.)
mark
05-30-2000 06:09:09
 Re: Re: VAC CASE CARBURETOR PROBLEMS in reply to BLR, 05-26-2000 10:41:29
Thanks. That inspection revieled why I hate putting these things back together in the field in the dark. The cotter pin tail on the gov. link was cought between the carb and the manifold. thanks again.
