Case DI power steering options
Ken in AZ
01-28-2006 07:47:36
I have a 51 or 52 Case DI with a loader that I would like to add power steering. I understand that some folks have had good luck putting power steering from later models onto the D series, as in maybe something from the 400 series. What does this entail? What kind of a pump, which parts from which model would you use, that kind of thing.
Thanks!
Ken in AZ
Mathias NY
01-29-2006 15:43:38
 Re: Case DI power steering options in reply to Ken in AZ, 01-28-2006 07:47:36
I don"t know anything about using parts from other Case tractors.
But if you have a live hydraulic source (like for the loader), you should be able to use that. I don"t know about the DI, but on the other D series tractors there is a steering rod that runs the length of the left side of the tractor. Depending on your level of creativity you could exchange this for a hydraulic cylinder. After that, all you would need is some kind of valving connect the steering wheel.
I have not actually done this, but I don"t see why it couldn"t be done.
