Sc case clutch adjustment
tj
04-29-2000 10:11:51
When i let the clutch out there is hardly anything
there. If I am pulling a disc etc. i need to put constant pressure on the clutch lever to keep tractor moving. according to the manual there is a lock pin in the adjusting collar but i cant find it. is it possible it could have fallen out?
any suggestions ?
Bob Z
05-01-2000 14:25:38
 Re: sc case clutch adjustment in reply to tj, 04-29-2000 10:11:51
The pin is spring loaded. Just the head is showing. Case furnished a tool to operate the pin. It had a small fork on the end. You can pull it back with needle nose pliers. While holding pin back tap clutch fingers clockwise to tighten the clutch.
