David Brown Water Pump
Trackhappy
04-28-2000 18:22:05
I have offered to help some friends by fixing the water pump leak on their David Brown 990 Implematic. I have pulled it off the tractor and I need to know the procedure to get it apart. It appears to be pressed together, and I assume I have to press off the pulley first, then press the bearing and shaft as a unit from the casting. Can anybody confirm this and/or offer any advice.
Thanks
Glenn in Brisbane, Australia.
Elmer
04-28-2000 18:27:34
 Re: David Brown Water Pump in reply to Trackhappy, 04-28-2000 18:22:05
Use a puller and pull the pulley off first. Then on some were a locating bolt that threaded in the bearing from the side. Then using a press push the bearing forward. Use a bolt or pin that will travel through the impeller. The pump housing will hold the impeller in place while pushing the bearing through. If you have difficulty finding the parts i have them. May even have a complete pump.
