case sc oil leak
Steve Davies
09-19-2006 14:48:26
1942 SC used for vintage ploughing in England,leaks oil below starter motor.Has the crankshaft seal failed ?
Is it a major problem to replace
Thanks for any help
Steve Davies
09-20-2006 14:05:40
 Re: case sc oil leak in reply to Steve Davies, 09-19-2006 14:48:26
Thanks for quick replies to query,not many SC`s in the UK!
Have removed starter motor, should there be any gasket or seal around the starter motor ?
Also what regulates the oil level in the clutch housing,does the oil run back into the sump?
C. Amick
09-21-2006 09:40:23
 Re: case sc oil leak in reply to Steve Davies, 09-20-2006 14:05:40
Yes, it is a cork gasket. I think it is still available from Case/IH for about $10. You may be able to seal it your self with a bead of silicone.
Yes the oil runs back into the sump. If there is a lot of gunk built up in the clutch housing, you may want to remove the side panels and the drain plug and clean it with some diesel fuel. Too much build up can cause the clucth plate to want to stick to the flywheel.
s davies
09-21-2006 13:58:18
 Re: case sc oil leak in reply to C. Amick, 09-21-2006 09:40:23
can anyone suggest a supplier of old case parts, especially gaskets, that would ship to England UK.
Yesterday Tractor Co will not ship abroad.
C. Amick
09-21-2006 14:28:48
 Re: case sc oil leak in reply to s davies, 09-21-2006 13:58:18
Email me and I will send you some information.
C. Amick
09-20-2006 09:29:35
To add to Gene's note below, the oil from the engine lubricates the clutch. You should drain the old oil from the clutch housing everytime you change your engine oil.
Gene Dotson
09-19-2006 16:01:16
Steve;
There is no rear main seal in your tractor. The clutch runs in engine oil delivered through a drilled hole in the crankshaft. The oil is leaking either because of a bad mounting cork gasket or through the nose seal in the starter. Either problem is cured by only removing the starter. If the oil runs down the block behind the starter, it is the cork gasket. If the oil is coming from below the starter, it is the nose seal... Gene
