VAC-14 Lift Questions
Jackey
03-29-2000 17:16:46
I have just recently purchased a Vac-14 case with
a 3-pt lift. The lift will raise just as soon as you crank it even when the lift lever is in the downward position, and it will not go down untill you shut down the tractor and then stand on the lift arms. What would cause this to happen? Also
where do fill the hydraulic system and check it?
Does the lift, rear end and trans all work off of the same fluid?
greg m
10-02-2000 19:37:55
 Re: VAC-14 Lift Questions in reply to Jackey, 03-29-2000 17:16:46
to let the 3pt down lever should be forward towards engine. This lever operates a cam which will actuate the valves. easy to get to.
remove the lift arm, then the cover and you will see the valves, there were several styles with different adjustments. I would operate by hand and see if you need adjustment or repair.
Dave
03-31-2000 14:36:50
 Re: Re: VAC-14 Lift Questions in reply to TMAC, 03-29-2000 17:46:42
It is true there is a dip stick on the trans, but that isn't where you check the lift fuild. You check the lift fuild level on the clutch petal side on the tube. It is a screw out plug.
