YOU HAVE A 1977 (LAST TWO NIMBERS) CASE 222 THE FIRST 2 MEANS LOW PROFILE (SMALL REAR WHEELS) AND THE LAST 2 MEANS 12 HORSE POWER. IT SHOULD HAVE A 12 HORSE SINGLE CYCLINDER KOHLER ENGINE.THE CLUTCH COULD BE BAD ON THE TRACTOR BUT MORE THAN LIKELY YOU HAVE EITHER A BAD PULLEY ON THE DRIVE BELT OR BAD BEARINGS ON ONE OF THE BLADE SHAFTS. STEP ONE: REMOVE DRIVE BELT (1.RAISE DECK, 2. SHUT OFF TRACTOR, 3. DISENGAGE DECK {MOWER OFF} 4.LOOSEN BELT BY TURNING FRONT HANDLE 5. REMOVE BELT BY TURNING IT OFF THE DRIVE PULLEY ON DECK 6. REMOVE FROM AROUND FAN BLADE.) NOW CHECK THE TWO IDLE PULLEYS UNDER THE FRONT OF THE TRACTOR (THESE ARE PART OF THE MOWER). IF ONE DOES NOT TURN FREELY, REPLACE IT. STEP 2: IF ABOVE PULLEYS OK THEN REMOVE MOWER DECK. (1. PULL THE TWO PINS ON FRONT OF TRACTOR. 2. START TRACTOR AND LOWER DECK. IT WILL PROBALY DROP OUT OF THE TWO FRONT PINS UNDER THE TRACTOR AT THIS POINT. IF NOT JUST PUSH DECK FORWARD AND IT WILL. 3. REMOVE PINS ON THE LIFT BARS. 4. BACK TRACTOR UP AND OVER THE DECK CAREFULLY.) NOW REMOVE THE DECK LID OF THE MOWER. YOU WILL HAVE TO REMOVE A COUPLE OF MORE PINS TO FILP THE LIFT BARS OUT OF THE WAY. ONCE YOU ARE INSIDE THE DECK REMOVE THE BELT. NOW YOU CAN CHECK EACH PULLEY/BLADE AND SEE IF THEY WILL SPIN FREELY. IF ONE OF THEM HANGS UP, EVEN A LITTLE, YOU HAVE FOUND THE PROBLEM. IF YOU NEED ANY MORE HELP E-MAIL ME AT [email protected] AND TITLE IT "CASE 222 DECK REMOVAL"
