DB990 Oil Leak
Don McDowell
09-19-2006 12:25:21
Hi,
I have a DB 990 Selectomatic. I am leaking oil where the tachometer cable connects at the side of the engine. It is leaking from around the back of the connector. Can someone tell me if the seal is provided by the cable assembly or if there is a separate tach drive assembly (?) that fits down into the engine that will have to be replaced in order to fix the seal.
Thanks in advance for the help
Don
