INfo needed on a Case 430 diesel
hey busdriver
02-25-2000 14:08:46
I am going to be looking at a Case 430 Diesel, in the next 2 days, can anyone give me any info on this tractor? I know nothing about Case tractors, the only two tractors I've had have been Ford(8N & 801) Is the Case 430 easy to get parts for? Are the parts expensive? What years would this tractor be made? Is this a relaiable tractor? I know the tractor needs paint, and needs a battery, but the owner says it starts good runs good, He owns several tractors and has never used this tractor, forgets how many gears it has. He says last time he started it was about a year or so ago, been sitting outside in the rain. I have only seen the tractor from a distance of 600 feet because of the tenats on property. Any input would be appreciated.
Stan
Gene
02-26-2000 09:12:17
 Re: INfo needed on a Case 430 diesel in reply to hey busdriver, 02-25-2000 14:08:46
I am currently rebuilding a Case 430D. So far I have been able to get parts from the local Case dealer without any problem other than having to wait a few days to have it shipped in. I have never run or worked on a tractor up to this point so I cannot give you a comparison. It appears to be a strong machine to my unexperienced eye. I bought it just because I liked the way it looked! I had gone to look at a Farmall that was for sale and the Case was over in the corner of the barn. Something told me that the Case had more "sex appeal" so I convinced the seller to let me have it instead. Don't know if I got a good deal or not but I am happy with what I got.
My unit is a four speed with a dual range transmission so I have 8 ahead and 2 reverse speeds. There is also a shuttle version but mine is not equipped with it. The only real problem that I have had was with the injector pump (bought a used one and solved that problem) and a noisy clutch. I have had a real problem trying to find out what was causing the noise and have had to split the tractor 8 times working on this. I think that I may be getting close to solving this problem and hope to have a final answer this week.
If I can help in any way, don't hesitate to contact me either through this forum or directly vai e_mail.
Gene Gillott
Vancouver, B.C.
