HELP! HYDRAULIC CYLINDER WON'T COME APART!
John James
02-10-2000 14:47:55
The seals in the hydraulic steering cylinders on my 430 are shot. According to page 20 of my I&T Shop Service manual, these cylinders should be easily disassembled by moving the snap ring on the rear of the piston into the lower groove and sliding the piston out of the cylinder. Doesn't work that way on mine. After moving the snap ring into the lower groove, the piston will move forward about four inches before it engages a postive mechanical stop inside the cylinder. No amount of "persuasion" will move it further. There is a welded seam around the cylinder about 3 inches from it's mouth. I'll bet that the cylinder is made from two different sizes of steel tubing which have to be cut apart to disassemble the cylinder. Am I correct? If so, it looks to me like the smart thing to do is find another pair of cylinders which don't have to be destroyed to be rebuilt. I would hate to replace (expensively) the cylinders only to later find out that I didn't know the "trick" to get them apart. Thanks for any help, John
Butch Keiper
02-14-2000 19:47:14
 Re: Re: HELP! HYDRAULIC CYLINDER WON'T COME APART! in reply to Caseworld, 02-10-2000 21:00:17
Your piston in your cylinder probably has a burr on it. Try taking a die grinder into the port and grinding enough off to get past the shoulder in your cylinder barrel.
Butch Keiper
02-26-2000 19:44:33
 Re: Re: Re: Re: HELP! HYDRAULIC CYLINDER WON'T COME APART! in reply to John James, 02-16-2000 16:40:19
I was able to push one of those cylinders apart one time with pressure from a hand pump. At about 2000 psi the piston pushed past the shoulder in the barrel. Nothing was damaged. This might work for you.
