2670 hyd leak,s
kirkC,
01-22-2006 07:05:54
My 2670 is streaming out hydralic fluid when running, but quits when engine is off,
I crawled under it and saw a line that was all oily,but not sure if that,s the one?
I saw the line is a straight one, not too long,
do i have to drain out fluid to fix it , or can I just fix the end of it where it start,s?
Kirk C,
John Saeli
01-22-2006 08:46:08
 Re: 2670 hyd leak,s in reply to kirkC,, 01-22-2006 07:05:54
Hey Kirk: Sounds like a pressurized line, so you should be safe not draining it. That doesn't mean you still won;t get a wet sleeve. Some of them lines are a pain to get at. Good luck.
