Changing fuel pump oil on 1370
agman
09-19-2006 07:46:00
All my diesel tractors require I change the oil in the fuel pump whenever I change the engine oil and use engine oil in the fuel pump, and explain it in the owners manual. I just bought a 1370 with the later serial number series and can't find anything in the manual on changing fuel pump oil, I would think I still need to do it, don't I.
Thanks.
dboll
09-19-2006 11:38:35
 Re: Changing fuel pump oil on 1370 in reply to agman, 09-19-2006 07:46:00
It is cheap ins. to change the rubber grommets on the pressure line to the pump. They get old and hard and have caused the line to come off. I know of a 1370 and 1570 this happened to. The 1570 spun a rod brg. before it was discovered. The guys were in a grain bin running a vac.
Bob
09-19-2006 08:03:16
That IP is lubed by a line from the engine's oil gallery, and the oil returns to the crankcase through the timing gear area.
