case 1175 PTO
kz9d
05-21-2008 18:43:38
I have a 1175. I had to rebuild the draft valve because it would not lift. It is better it lowers at lower rpm's and go's down when the tractor is turned off. I brush hogged a spot the other day and the PTO worked fine (hit some dirt when mowing). Today I mowed again and I hit some dirt and everything seemed to work fine. About 5 min into the mowing the PTO slows dowm when I get into the heavy grass and will not cut.
