Case C
Cory Christison
05-21-2008 06:15:43
My Uncle has a 1936 (he thinks) Case C that I want to get running. The tractor has been restored, but has sat a number of years. I'm just wondering where you would check the oil in the crankcase before I try to turn it over? It's probably pretty obvious, but the tractor isn't with me, it's at my parents farm. Thanx for your help guys!!
R Aiken
05-22-2008 12:10:39
 Re: Case C in reply to Cory Christison, 05-21-2008 06:15:43
Before you crank it ,take off the hood and valve cover. Clean and oil the valves, rockers and pushrods. Tap the valves with a hammer to be shute they are not stuck.
mEl
05-21-2008 08:43:16
I have an original owners manual for an early DC ,39. It instructs that after a tractor sits idle for an extended period that the side covers should be removed , and the cylinder walls saturated with oil to avoid a dry start. may save engine damaged , but I'll bet it don't get done often. mEl
Brian in Ohio
05-21-2008 06:20:47
There are two drain plugs on the mag side of the oil pan. The top one is the "FULL" level and the bottom one is the "LOW" level. You add oil through the cap where the governor is located.
