Had fun today.
jjamna
05-20-2008 19:32:57
Wish I had the wife take some pictures but I didn't. Planted 8 to 10 acres of corn today with my 48 SC pulling a 494A John Deere planter. I was worried if it would handle it but it did fine. Worked a little bit going up hill but they all do.
Had been using a 48 H Farmall but I think I have a new planting tractor. Everything went so smooth and turning around was a lot easier than with the H.
Sure wish I had some pictures.
Just wanted to share this with you guy's
Hope everyone has as much fun as I do with these old tractors.( Fun all but buying fuel)
jim handke
05-22-2008 05:19:08
 Re: Had fun today. in reply to jjamna, 05-20-2008 19:32:57
I started farming on dad's 49 SC. Mowed hay with a New Idea mower and used a 2 row cultivator. That was way back when farming was fun.
jjamna
05-21-2008 10:00:49
My SC pulls my 2 bottom plow a lot beter than the H does. Pulls in 2 gear also. However I have a 48 M also and The case don't do as good as the M but that is to be expected
C. Amick
05-21-2008 09:23:13
I've never owned a Farmall H and just wondered why the Case SC was easier to turn around? Does it have a shorter turning radius or is easier to steer? I have a set of 2-14" MH plows that the neighbor said his Farmall H wouldn't pull. I can pull them with the Case SC in 2nd. gear. I guess his Farmall H just needs some work?
c.hess
05-21-2008 17:52:42
 Re: Had fun today. in reply to C. Amick, 05-21-2008 09:23:13
If you have ever driven a jd or farmall made same years you will very quickly realize who had best steering=Case no comparison . You can drive Case with 1 hand including over furrows!!!!! !
C. Amick
05-22-2008 09:03:42
 Re: Had fun today. in reply to c.hess, 05-21-2008 17:52:42
You can't say the same about the VAC, though. My VAC is much harder to steer than my Farmall C.
Don Livingston
05-21-2008 05:48:50
I had fun too , yesterday I plowed 5 acres myself. Hope to do 25 acres more when he applies the ole cow manure. Don L.
Mike Schotte
05-21-2008 06:05:59
 Re: Had fun today. in reply to Don Livingston, 05-21-2008 05:48:50
Sounds like you both had fun!
