Case 970 3pt problem
Jarrod S
05-20-2008 19:23:55
Having some problems with my 3pt on my 970. Got the plow hooked up ready to go....only my 3pt was sluggish on lifting.....now it doesn't lift at all....but the you can hear the pump working...everything else is working fine hydrolicly...cylinder---steering etc. Any tips if this is just an adjustment on the draft o matic? Thanks for any help.
Dairy Farmer in WI
05-21-2008 19:26:51
 Re: Case 970 3pt problem in reply to Jarrod S, 05-20-2008 19:23:55
be sure to check the hydralic filters. the 3 point weight adjust ment is right next to the PTO and it says "sensing" right underneath it. otherwise i don't know
DF in WI
