730 Case 3pt. hyd problem
TAH
05-20-2008 19:15:19
The 3pt. drops after shutting tractor off by itself also in the up position with tractor running it keeps going up and down about 4 inches. Can anybody shed a light on this? Thank you
DKase
05-21-2008 05:28:50
 Re: 730 Case 3pt. hyd problem in reply to TAH, 05-20-2008 19:15:19
Your lowering valve is stuck open. The draft sensing is trying to keep it up, but the leaking valve is letting it go down. Valve is behind the small plate on the side of the 3 pt. valve under the platform, under the seat.
TAH
05-21-2008 06:37:22
 Re: 730 Case 3pt. hyd problem in reply to DKase, 05-21-2008 05:28:50
Would the lowering valve be dirty or would this have to be replaced? I have an I&T manual and was looking at it, the shuttle valve comes out also from under that cover, correct?
Camboted
05-20-2008 20:59:34
Do you have the "Comfort King"with the internal cylinder or the older model with the external cylinder??
TAH
05-21-2008 06:47:56
 Re: 730 Case 3pt. hyd problem in reply to Camboted, 05-20-2008 20:59:34
It is a 1969 CK diesel.I have a loader on it and that works just fine
