SC troubleshooting
Ken Christopher
05-19-2008 10:09:19
Had the SC out again today. Looked at where the impulse was clicking. It was a little advanced. So I got it dead on there. I also played with the carburetor (gas cap off). Got the idle adjustment out 3 turns. It doesn't seem to matter where the load adjustment is at. As long as it is more than a 1/2 turn out it seems to at least run. I can't for the life of me figure this out. As far as I can tell, the timing is dead on. I have all new fuel lines, fittings, sediment bowl, tank was blasted and seal coated inside, new carburetor, tried running with the fuel cap off. Spun the magneto to retard and advance timing. Runs the best with it advanced all the way (this is also at the point where the impulse clicks with the timing mark on the flywheel visible). I have blue spark. The only thing left for me to check is the adjustment of the valves. But I have not touched them since I took them off. The tractor ran pretty good before I tore it down.
C. Amick
05-20-2008 18:55:31
 Re: SC troubleshooting in reply to Ken Christopherson, 05-19-2008 10:09:19
Could be starving for gas?? Does engaging the choke a little make any improvment? Could be something as simple as the carb float being set too low. Better check those valve clearances also.
J Heitkemper
05-20-2008 07:08:28
Ken . This Could be Your problem , Check Your exhaust and intake manifold , sc's were NOTORIOUS for burning thru and sharing gasses ,AND CONSEQUENTLY MISFIRING . But ,they can be REPAIRED . It is my opinion the sc was a CASE mistake, I have had 3 sc s that have played me for a fool . I never could get the governor right. sc s just don't run like a VAC or DC. best Wishes Jim
old
05-19-2008 10:35:00
Can you adjust the main jet to thew point you get black smoke out of the exhaust pipe??? If you can't then the main jet is probably clogged up by some dirt of rust. Pull the drain plug out of the bottom of the carb and also pull the main jet out. Spray some carb cleaner into the main jet and let it run out the drain. Spray it out real good. put the main and plug back in and see if that helps any. Also if you can pull the main jet adjustment out all the way and hold it in your hand and the tractor still run you know 100% sure the main is clogged or the bowl vent in the carb is clogged
c.hess
05-19-2008 15:58:58
 Re: SC troubleshooting in reply to old, 05-19-2008 10:35:00
After you are positive carb is ok an still not satified i would be concerned about what you said about having to turn mag fully against stops to time corectly. Seems to me you should have some movement left eighter way to advance or retard. Could you have cam train off somewhere? Than again sc were not the hottest hotrod in there day.
