Case 1070 power shift
Dan M.
05-18-2008 18:57:30
I am rebuilding the power shift in my 1070
is it normal when i put air pressure to the c2 (center hole in the oil distribution block), to have some air leaking out of the c3 hole.
mEl
05-21-2008 05:23:14
 Re: Case 1070 power shift in reply to Dan M., 05-18-2008 18:57:30
There should be no connection between the c2-c3 passages, they are seperate passages with no interconnection at all, the clutches are spring released and do not depend on oil pressure to withdraw the pistons, if I had that issue going on I would find out why.
garyga
05-19-2008 15:15:41
Dan M. said: (quoted from post at 03:57:30 05/19/08.)
I am rebuilding the power shift in my 1070 is it normal when i put air pressure to the c2 (center hole in the oil distribution block), to have some air leaking out of the c3 hole.
Yes, you need to have some air release back out of the c3 hole.
