DE Combine Engine
Bunkumben
05-18-2008 17:01:19
The tag on the Case DE engine I bought at the auction at Santa Claus IN has serial number 5508720 on the tag. Am I correct in thinking it was built in 1951? I hope to use this as the replacement engine in my D.
Thanks in advance,
Ben
combinekid
05-20-2008 22:36:41
 Re: DE Combine Engine in reply to Bunkumben, 05-18-2008 17:01:19
I have a DE engine out of an SP 12 combine engine. I would be interested in selling. I am in WA state. e-mail me if interested.
caseman-d
05-19-2008 20:43:59
Bunkumben said: (quoted from post at 17:01:19 05/18/08) The tag on the Case DE engine I bought at the auction at Santa Claus IN has serial number 5508720 on the tag. Am I correct in thinking it was built in 1951? I hope to use this as the replacement engine in my D.
Thanks in advance,
Ben
Ben,
I put a DE engone in my D. I did have to change front front pulley and Also think I had to change flywheel and seemed like there was a plug in the crankshaft that you needed to remove and put in the little valve to oil the clutch. Been a few years, but over all was easy switch. I also removed the side inspection plates and cleaned up the pan inside.
caseman-d
wilson
05-18-2008 18:23:47
you are correct also the de should have 4 inch alumium pistons and a snapper govenor and rated 200 rpm faster than the d engine
Lamont
05-19-2008 07:20:19
 Re: DE Combine Engine in reply to wilson, 05-18-2008 18:23:47
My 53 DC has a DE engine on it. It definitely has that snapper governor and more rpm. It cranks out a solid 50hp on the dyno too. I understand the D is for the series, but what is the E designation?
Mike Schotte
05-19-2008 11:06:28
 Re: DE Combine Engine in reply to Lamont, 05-19-2008 07:20:19
The "E" would be for engine unit. SE, DE, etc.
"EX" would be the export model.
Bunkumbrn
05-20-2008 18:23:06
 Re: DE Combine Engine in reply to Mike Schotte, 05-19-2008 11:06:28
Thanks for the information everyone. My son and I might try to perform the switch this weekend. I guess I don't understand what needs changed to oil the clutch. Is it inside the clutch housing? Also can I measure the crank pulley or check for casting numbers to see if they are the same?
caseman-d
05-20-2008 20:34:11
 Re: DE Combine Engine in reply to Bunkumbrn, 05-20-2008 18:23:06
Picture of rear of crank
third party image
If my memory is correct I couldn't get the front end back on with combine pulley;
third party image
third party image
third party image
Hope this helps
caseman-d
caseman-d
05-20-2008 19:51:22
Bunkumbrn said: (quoted from post at 18:23:06 05/20/08) Thanks for the information everyone. My son and I might try to perform the switch this weekend. I guess I don't understand what needs changed to oil the clutch. Is it inside the clutch housing? Also can I measure the crank pulley or check for casting numbers to see if they are the same?
You can tell the difference in the front pulleys. The D series have wet clutch which gets it supply from engine through the crank. The combine egine does not have a wet clutch and the end of the crank may have a plug in it. Once you have your old engine off you can see what I'm referring to. I can check and see if I took pictures.
caseman-d
Bunkumben
05-21-2008 18:03:41
 Re: DE Combine Engine in reply to caseman-d, 05-20-2008 19:51:22
I checked the pulley tonight. It will have to be changed. I got the drive off but still have to take the housing and flywheel off. I might have to delay the project, if the ground dries enough I have to get our corn and beans planted and the hay is not very far behind.
Thanks again,
Ben C.
