dc steering
keith52
05-18-2008 07:26:44
I have a 1948 dc I need to repace the seal or bushing which ever it is on the steering shaft closes to the steering wheel. Does any one know where to get one and a part number.Thank for your help.
Keith
Don Rudolph
05-18-2008 07:56:49
 Re: dc steering in reply to keith52, 05-18-2008 07:26:44
Keith,
I am assuming you mean the bushing at the top of the steering column that has a grease fitting going through it. It normally would be a very cheap fix, however, if the bushing is worn out chances are good that the shaft is worn bad also. I have my machine shop true up the shaft all the way back to the top and then make an oversized bushing to fit. If you do not want to spend that kind of money a new bushing which will be better than what you have now can be gotten from Grainger or McMaster-Carr much, much cheaper than from IH.
