dc case clutch/transmission problems
joe fadiga
05-17-2008 21:20:48
My father had a DC case sitting in the pasture that hasn't been moved or started in about 2 years. We went out and tried to pull it to get it started, we had pulled it about 10 feet and it started and died, we tried it again and were unable to pull it. both tires just skidded across the ground even with the clutch disengaged. The wheels won, roll unless the tranny is in nuetral, aslo with the tranny in nuetral and the cluch engaged you can't turn the motor over. Everything worked great when it was parked 2 years ago and never gave us any trouble. please help me.
Bob from Australia
05-18-2008 19:53:35
 Re: dc case clutch/transmission problems in reply to joe fadiga, 05-17-2008 21:20:48
If it is two gears engaged, it is easy to take the cover off the transmission and use a bar or large screw driver to disengage them.
Unfortunately it is also a possible indication of transmission problems such as bearings.
Klyde
05-18-2008 16:40:42
I think its somthing with the PTO boys. What year is it? If it is new enuf to have live PTO it may be somthing with the hydraulics. make sure the pto is off.
wilson
05-18-2008 07:07:42
Ted and you guys are usually right on but this time you all have a brain f##rt. He said wheels will roll when transmission is in neutral!!!!! !!!!! !! Look to the engine hope its a valve sadly that starting then apparently locking makes me wonder Did you check oil first and drain out some oil to check if water had got in crankcase? as fine as the case motor is water is not a good lube for the bottom end.
Camboted
05-18-2008 03:07:25
Since it started I have my doubts about the valve train. You could jack up one side at a time and see if one of the wheels turns (while in neutral). Probably one of the clains set up over time, and being loose, a roller is stuck on top of a cog on the dirver sprocket. Try turining it backwards. It may come loose, but if it does, you need to check the chains before driving it much.
Bob from Australia
05-18-2008 02:51:59
Stuck valve train is common. DO NOT pull the tractor, if this is so, you will bend a push rod (don't ask me how I know this!)
Take the valve cover off to check.
ben mc
05-18-2008 01:35:15
i was told never to pull a case because they are chain driven and the chain can come off maby that is what happend??
Glenn F.
05-18-2008 06:26:25
 Re: dc case clutch/transmission problems in reply to ben mc, 05-18-2008 01:35:15
Those chain drives are RUGGED. NO problem pulliing 'em if they're properly adjusted.
Glenn F.
joe fadiga
05-18-2008 13:22:24
 Re: dc case clutch/transmission problems in reply to Glenn F., 05-18-2008 06:26:25
I don't think its in the valve train the engine turns freely as long as the clutch it disengaged but will not turn over with the tranny in nutral and the cluch engaged
wilson
05-18-2008 15:05:03
 Re: dc case clutch/transmission problems in reply to joe fadiga, 05-18-2008 13:22:24
sounds like possibly in 2 gears at once how does gear shift lever feel possibly out of lower notch????? ??
joe fadiga
05-18-2008 13:28:25
does anybody have a diagram of the clutch and drivechains and maybe the tranny if i have something to look at i think i can figure it out
Tom Railsback
05-18-2008 15:30:14
 Re: dc case clutch/transmission problems in reply to joe fadiga, 05-18-2008 13:28:25
*It's in the online parts book at CNH.com.
joe fadiga
05-18-2008 13:28:09
joe fadiga
05-18-2008 13:28:07
