700 Diesel Pre-heater
Kurt Smit
05-17-2008 11:16:56
Does anyone know if the battery operated pre-heater, in the manifold of a 700 diesel, fits in the same hole that is used for the ether injection? I have the fitting in the manifold for the ether injection (pinched off by previous owner) and would like to switch to the battery operated pre-heater, I think, if they work, it definately needs something, it starts hard cold. Any information/tips would be great.
Thanks,
Kurt
genes not exactly right
05-19-2008 09:46:52
 Re: 700 Diesel Pre-heater in reply to Kurt Smit, 05-17-2008 11:16:56
On a loose engine poor injectors will often help starting as the excess fuel helps seal compression,a good injector will help considering the rest of the engine is good in regard to cyl. wear and valve seal, as usual Gene is offering his misinformed assistance!!
Gene Dotson
05-19-2008 11:48:10
 Re: 700 Diesel Pre-heater in reply to genes not exactly right, 05-19-2008 09:46:52
Whoever you are, I challenge your remarks. There is no improvement whatsoever with running a malfunctioning injector. I have owned my 700 for 36 years and when it begins to start hard, I pull and clean and lap the injectors and it starts and runs much better and smoother.
The advice I offer here is from many years of working on and with tractors. I am proud to sign my name to all posts I make here. There may be times I have made errors, but on this subject thread I will stand firmly on both feet with the advice I have offerd.
Gene Dotson, De Graff, Ohio
Gene Dotson
05-17-2008 13:46:51
Kurt;
Most common cause of hard starting is dirty or worn injectors. These can be removed and cleaned or new tips installed. Adjust cracking pressure to 2500 to 2700 PSI. The original ether starting aid used a jel capsule inserted in the plunger. It is difficult or impossible to find the capsules.
I discarded my ether system many years ago. When I need ether, I just give a very little puff in the air cleaner.
Cranking speed is also very critical. One battery will not spin the engine fast enough when cold to start. Best setup is 2 group 24F batteries in parallel in place of the 2 six volt batteries in series. Must have at least 0 gauge cables to carry the load... Gene
Kurt Smit
05-18-2008 06:26:09
 Re: 700 Diesel Pre-heater in reply to Gene Dotson, 05-17-2008 13:46:51
Thanks! I have good batteries and big cables, but have suspected the injectors are worn/dirty. It"s been sitting for quite a while so I wanted to try to run it some before pulling the injectors.
Thanks!
Gene Dotson
05-18-2008 14:17:32
 Re: 700 Diesel Pre-heater in reply to Kurt Smit, 05-18-2008 06:26:09
Kurt;
The injectors can cause other problems as well. With a poor spray pattern the injectors will cause erosion of the power cell nozzles.
I just bought a pair of heads from a 800 and the spray pattern had ruined 3 out of the 4 power cells. Fortunately, I have enough good cells to use in these heads. I will be rebuilding my 700 this fall or winter and want a set ready to bolt on... Gene
Tim in New York
05-17-2008 12:08:34
Hi Kurt,
The previous owner of my 700 did just that. The ether line and fitting still dangles right underneath the heater element. Mine doesn't work any more - just one more part to be fixed during my restoration.
Tim
Kurt Smit
05-18-2008 06:27:19
 Re: 700 Diesel Pre-heater in reply to Tim in New York, 05-17-2008 12:08:34
Thanks, will try this also.
Kurt
