Vin information
Dodge Man
05-17-2008 08:42:29
Hello,i have a Case VAC and it has no vin number and i want to know, if i give the engine number can you give me the vin number from that Tractor?
Joe (Wa)
05-17-2008 18:08:25
 Re: Vin information in reply to Dodge Man, 05-17-2008 08:42:29
Va series did not have the tractor serial nr anywhere but on a metal tag on the dash.
The engine serial nr will be stamped into the block above the starter, early models stamped just below the head gasket, later models lower down on the block and sometimes vertical as opposed to horizonal (how's that for butchered grammer?).
If the engine is factory original, the model year(s) of the tractor can be ballparked within a span of years with some overlap by the engine serial nr using the parts catalog (more butchering).
Joe
patsdeere
05-17-2008 10:14:41
I don't know what you are calling a VIN number, but if you look at the flange where the engine bolts to the transmission case, there should be a nunmber stamped in it. I don't know about that model, but I think most are on the left side. Once you get that you can look up the S/N and it will tell you the year.
CWH
05-19-2008 10:41:59
 Re: Vin information in reply to patsdeere, 05-17-2008 10:14:41
The VIN is the Vehicle Identification Number, what a lot of folks refer to as the serial number.
dieseldave56
05-18-2008 23:14:31
The Case model/ production date are stamped on the left side (when seated on the tractor) engine /bellhousing flange . The first numbers are the production date minus 4 (i.e.5400000VA is 1950) the last letters are the series/model designation.
