Seals are in, but brakes still very weak, what next?
Soldier Tom
05-16-2008 16:19:59
O.K. got the seals changed out and the river of 90 weight dammed up. (It was a lot easier than it looked like it would be!)
I cleaned up the brake shoes with brake cleaner and scrapped off the face of them real good with a knife blade. They looked pretty when I put them in. They were new 25 years ago when the tractor was parked. The brakes will slow the tractor down now, but will not lock up the wheels no matter how hard I stand on them. The drums are not pitted at all and also appear to have been new when the tractor was parked, still some paint on them even.
Any more tricks I can do before popping for new brake shoes?
~Walk in peace~
GEOMO
05-19-2008 07:38:07
 Re: Seals are in, but brakes still very weak, what next? in reply to Soldier Tom, 05-16-2008 16:19:59
I HAD THE SAME PROBLEM ABOUT 50 YEARS AGO.
I ADJUSTED BRAKES UP AND TOOK OF DOWN THE ROAD.
THEY LOCKED UP AFTER ABOUT 200 YARDS. I BACKED THEM OFF AND HAD GOOD BRAKES.
CAREFULL ADJUSTMENT IS A MUST.
Soldier Tom
05-18-2008 05:26:20
Well, I took the shoes and soaked them in brake cleaner good, then let them air a little while to evaporate most of the flamables, then hit them with a little propane torch, systematicly burning/boiling out the oil. Then I hit the pads with heavy sand paper, and did the same to the brake drum, roughing it up good.
Put it all back together and it works like a charm now. Both wheels will lock up and skid the tires. Then I adjusted the levers until they had the same "feel". I don't think it would scare me too much to get this on the road now, (once I get the lights working that is!). Gonna have to weight them wheels tho, that's for sure!
Yall have good advice, thanks again! I will be hollering back when I go to dig in to the Eagle Hitch piston!
~Walk in peace~
Larry 400
05-17-2008 10:01:55
What are these brakes on? When ever I repaired brakes/grease seals I found that the brake lineings were saturated with grease. Soak them in gas,then lay them out in the drive way and set them on fire. You'll be surprised at how much grease boils out of them. After they cool they will be good to go.
garytomaszewski
05-16-2008 19:49:51
Tom, I missed your earlier posts so here's advice without knowing what I'm talking about. There were few of the older Case brakes that would actual lock up and skid a tire, they were strictly turning aids or parking locks. DCs have a great mechanical drive advantage over brakes, you can actually drive with a brake locked until the grease in the drum goes up in flame,really embarassing.
Jiles
05-16-2008 19:17:57
I feel the same as you, concerning re-salvaging good parts. My guess would be that the shoes were not replaced in the same position as removed. I would "ride" the brakes heavy for a short time. This will reveal wear or friction marks on the shoes to determine how much surface is in contact. Also check the drum surface.
RickB
05-16-2008 16:51:07
New shoes are the best answer if you want to stop.
Soldier Tom
05-16-2008 17:20:02
 Re: Seals are in, but brakes still very weak, what next? in reply to RickB, 05-16-2008 16:51:07
You're probably right Rick, but I am a die-hard cheapo and from the receipts I've collected; fluids included I have just over 700 bucks in the whole thing. I am trying to use all the "farmer short cuts" I can to save for gas to go in the tank! Thanks, tho for your quick response. Rekon CASE still sells them brakes don't they?
~Walk in peace~
caseman-d
05-19-2008 20:33:23
 Re: Seals are in, but brakes still very weak, what next? in reply to Soldier Tom, 05-16-2008 17:20:02
Soldier Tom said: (quoted from post at 17:20:02 05/16/08) You're probably right Rick, but I am a die-hard cheapo and from the receipts I've collected; fluids included I have just over 700 bucks in the whole thing. I am trying to use all the "farmer short cuts" I can to save for gas to go in the tank!
~Walk in peace~
Check with your auto parts store, you may be able to match something up bt numer of splines and diameter. Also try like TSC, A&I, Hycap. Lots of other choices to buy from. Case/IH used to be cheaper than aftermarket but over the past 10 years they have really jumped and quality went down. I used to always preach OEM but past 5 years working with CNH dealer I have lost faith in the OEM parts. Some are still better, but seem far in between past few years.
caseman-d
RickB
05-17-2008 03:06:24
A good soaking/scrubbing with 20 mule team Borax works about as good on brake shoes as anything.
