Inj pump for 520 Case
Hoss in Me
05-16-2008 07:52:48
I got the 520 running and goes good.Has the single plunger rotary pump in it.Will the pump off the 900Case ,which is the inline multiple plunger bosch design give it more oomph?Or hp?
mEl
05-18-2008 03:44:42
 Re: Inj pump for 520 Case in reply to Hoss in Me, 05-16-2008 07:52:48
The required gear reduction change is in the adapter that bolts to the block, the Robert Bosch has a gearset that changes the speed. I have changed them over, just change the external stuff, no need to open the engine up for gear changes.
DKase
05-17-2008 05:08:25
I'm not sure what is involved to change it, but I know of several guys that have changed theirs and said the governer was better and they did pull much better.
Hoss in Me
05-16-2008 10:04:23
Pump on 520 is amer bosch psb6a-75d-3411b1.I just looked closer and mount is different than 830 with 301.520 has 6300-a eng.Maybee I got some wrong info? Hoss
Hoss in Me
05-16-2008 09:53:27
My 830 has same mount setup as this 6 cyl engine.The 900 has same eng but uses inline pump.was wondering of if there were any advantages either way? Hoss
J Schwiebert
05-16-2008 09:45:40
Clue me in here a little bit. If your single plunger pump is a Bosh PSB you will need to make some other changes. The PSB single plunger Bosch pumps run at crankshaft speed. Multiple plunger pumps run at cam shaft speed. So timing gear changes will need to be made. How about posting the model number of your pump and if you know it the inline pump as well. J.
