SC is running!
Ken Christopher
05-16-2008 05:51:31
Well, got the oil pressure line in yesterday. Cranked it over and she runs.... Rough but none the less, she runs. Shut it down, put on the radiator, and filled it with coolant. Started it up. Took it out of the garage. Seems like a large lack of power. Underpowered in all gears, especially fourth. I am assuming it will be because the magneto is still not quite timed right? I am reading through the troubleshooting section in the repair manual and none of the factors like sticking valves seem to be right. They all seem pretty loose to me. Let me know with your thoughts. Thanks guys!
Ken Christopherson
05-17-2008 12:18:53
 Re: SC is running! in reply to Ken Christopherson, 05-16-2008 05:51:31
I have bright blue spark. Have not checked flow to the carb. However, It is a new carb (Zenith 9667). New sediment bowl. New fuel line. The gas tank has been blasted inside and out, pressure tested and sealed. I will try fussing with the needles some more tonight. I don't think that it is out of time because I was almost dead on with the magneto directly vertical watching for the mark on the flywheel. If anything I should retard the timing just a tad. If anyone is having a boring weekend here in MN and has nothing to do. I will be working on it most of the weekend as far as I can tell... Ha Ha! Otherwise I will keep you posted. Any other thoughts let me know. Also getting a lot of backfiring out of the carb. (which would mean starved for fuel most likely).
Kenny
Ken Christopherson
05-17-2008 06:41:49
I tried adjusting the load screw. had it 4 1/2 to 5 turns out. Still not much better. Then tried advancing the spark and retarding the spark. Seems to run a little different fully retarded but can't tell if it is better or worse (not much of a difference). Also discovered that the seal behind the pulley on the waterpump seems to be leaking slightly. I am confused on what to do with how it is running. It also will not idle without stalling.
Mike Schotte
05-17-2008 09:21:05
 Re: SC is running! in reply to Ken Christopherson, 05-17-2008 06:41:49
Another not so obvious issue with fuel starvation is to check the gas cap.
Make sure that pinhole breather vent in the cap isn't painted over.
I have fuel problems every time I try to "improve" my fuel line and filter. Longer and more complicated never worked... since it's gravity fed.
Just another thing to think about.
also check spark
05-17-2008 07:22:00
Ken - if it is getting enough gas you might check the gap on your points. It is better to set them to wide instead of too narrow. If too narrow the spark will be weak as it will have a shorter gap to jump. Check spark on a plug in a darkened area. Blue is good, yellow is bad. Good Luck! Todd Hamilton
and get rid of the mag
05-17-2008 07:26:31
 Re: SC is running! in reply to also check spark, 05-17-2008 07:22:00
Ken - SCs run better with the distributor conversion and they are easier to work on. The Delco kit for a Farmall H will fit it (I think). Most of the old-timers on the board will disagree with this recommendation. Todd Hamilton
todd hamilton
05-17-2008 07:07:51
It is not getting enough gas - common problem on SC. It will start and run on a trickle of fuel flow but have no power. I have seen my Dad run his in from the field a dozen times and he would blow out the fuel line and take the bottom off of the carb, blow it out and check the float. Mine had a habit of picking up crud from the gas tank inlet - be sure to check it as I had this problem more than once.
garytomaszewski
05-16-2008 08:58:50
Full flow of gas to carb? Open drain valve and check, I like a pint in 2 minutes or less. Per Case manual; Turn load adjustment inward until the needle just seats. Use great care not to force the point against the seat as this may ruin the seat. Next turn the valve outward two full turns. Make final adjustments when the engine is warmand working under full load. If you've done the static timing with the dot centered in the inspection hole, with .the engine runing barely loosen the mag bolts and move the top of the mag away from the engine this advances timing
Mike Schotte
05-16-2008 08:05:57
I can't tell you for sure- but I think my load screw on the carb is about 4 to 5-1/2 turns out. (Zenith 9667 carb) I'd have to run the brush hog, fiddle with it, run the brush hog some more to tell where it needed to be. Couldn't tell any difference at all in how it runs at idle.
Underpowered in 4th gear? You better be hanging on to the steering wheel and be ready to jump for safety in 4th on my SC! (grin)
The only other times I had loss of power were when I had a fuel blockage, and when the mag condenser went bad on me.
todd hamilton
05-17-2008 07:15:20
 Re: SC is running! in reply to Mike Schotte, 05-16-2008 08:05:57
I have told this story on the board before - Dad's old '41 had an LP head that was milled. When I was about ten years old I have plowed with that thing pulling 2 18s up a red hill in 1st gear with the front wheels in the air. I would hang onto the steering wheel with both hands, butt on the front edge of the seat, both feet working the brakes to keep it in the furrow. It would be considered "child endangerment" today!:^)
jal-SD
05-16-2008 07:23:54
Sounds like the main jet in the carb may need to opened up some, how many turns out is it? If I remember right, the manual tells how many turns to set it initially & then tells you how to set it after it warms up. If I don't forget, I'll hunt my manual up at noon & look at what it says. (My $0.02 worth. jal-SD)
