VAC brake seals
Soldier Tom
05-16-2008 04:30:11
Quick question please; to stem the tide of 90# oil running out the brake weep holes, I bit the bullet and got seals, got the old ones out no prob, (They were shot for sure, I put a pic in stuck and troubled). Also I ended up having to buy a 2 1/4 socket for 20 bucks, Wow. Anyway I've heard to replace the seals with two new ones but don't quite get it as to why. What if I used just one? Can someone with more knowledge enlighten me? Thanks in advance.
~Walk in peace~
Randy in NE
05-16-2008 05:48:09
 Re: VAC brake seals in reply to Soldier Tom, 05-16-2008 04:30:11
The new seals are only about 1/2 as wide as the old ones. However, they are made of much better material than the old one. Some people put two seals in thinking that they need to fill in the entire recess area. If you think about it, only the inside seal is going to be in contact with oil/grease and be lubricated. The other one is going to be dry and rubbing on the shaft. It won't take long for that seal to be worn away. The best thing to do is to exam the shaft and look for worn area. Then align the new seal up with a good area on the shaft.
mikefromiowa
05-16-2008 04:57:55
I replaced mine with 2 seals. the new ones are only about half as wide as the old ones. I put the first one in correct direction, the second backwards
TimBinWV
05-16-2008 17:12:24
 Re: VAC brake seals in reply to mikefromiowa, 05-16-2008 04:57:55
Sounds like a good idea...keeping the dirt away from the seal x 2....
