case v trany oil type
mr rudy
05-15-2008 17:19:06
Could you please tell me what type of oil goes in a case v tractar serial no 4518862 thanks
Gene Dotson
05-16-2008 02:42:51
 Re: case v trany oil type in reply to mr rudy, 05-15-2008 17:19:06
Use 85W90 year around. Will work fine... Gene
dieseldave56
05-16-2008 01:40:45
Mr Rudy; My 1950 Case DI service manual calls for 10 1/2 gallons of SAE 140 fot temps 32F and above and SAE 90 for below 32F. Note; if the tractor is to be used in cold weather ( below 32F) with SAE 140 , drain 2-3 gallons and repalce with a good grade of SAE10 or 10W engine oil. In the Case Model D series tractor operators manual the lube is SAE 90 for both winter and summer with a 10 1/2 gallon capacity. To be change every 2000 hours. Can't see how the spec would be any different on your V series.
