A few VAC Questions
Too Far Gone
05-15-2008 13:07:04
Hello,I need to know approx weight of a VAC with WFE,hydraulics,one pair of wheel weights,and eagle hitch.Id also like to know where the check plugs for rear end and hydraulics are located.I know the fill plug for the hydraulics is at the bottom of the dash,and I found the drain plug on the rear end,but I dont know for sure where the check plug is for the rear end or the hyd.Thanks
Too Far Gone
05-15-2008 16:57:15
 Re: A few VAC Questions in reply to Too Far Gone, 05-15-2008 13:07:04
I found'em.Thanks for everybodys help.
Sam#3
05-15-2008 16:03:30
The transmission/differential is checked with a dipstick on a plug by the left floorboard.
The hydraulics are checked and filled through a hole on the left side of the torque tube. The triangle shaped cover near the fill hole covers the hydraulic filter.
Glenn F.
05-15-2008 13:40:22
Approx. 3400#
Glenn F.
