Vac clutch
David Nelson
01-30-2000 11:23:14
Does anyone have any tricks for a sticky clutch? My clutch on my vac wont let you shift into gear after you shift into neutral. Please help I just put a new paint on it and do not want to split the tractor.
Lew
01-30-2000 20:06:41
 Re: vac clutch in reply to David Nelson, 01-30-2000 11:23:14
An old trick we used on another brand tractor with a sticky clutch, was to park it with the clutch depressed. We did this by cutting a piece of 2x4 so that it held the clutch pedal down while braced from the seat or some other solid point. We notched the ends of the proper length 2x4 so that it would not slip. It did not cure over night but over several days it helped greatly.
