Ridge Reamer or Not
KevinT
05-13-2008 18:00:28
I am rebuilding a A267D Diesel and will only be replacing 1 sleeve and piston. The others are within spec and will be ball honed and get new rings. However, they have a ridge and I am afraid that the new rings might catch it. I have heard mixed reviews about using a ridge reamer but have not seen other options besides boring and that is out of the questions as this is an in-frame rebuild. What are the recommendations. Thanks
Walt davies
05-15-2008 06:22:07
 Re: Ridge Reamer or Not in reply to KevinT, 05-13-2008 18:00:28
Contrary to popular belief the ridge reamers are only used to remove a piston from the sleeve. After that the sleeve must be bored out to the next size or replaced as there will be to much clearance between the piston and the sleeve due to wear.
If you can get the piston out the bottom of the sleeve you wan't need the reamer.
Walt
El Toro
05-14-2008 08:06:02
You need a ridge reamer like these or you will break the piston when trying to remove it. All cylinders need this if installing new bearings since the new rings may hit the ridge. Hal
third party image
third party image
george md
05-13-2008 20:48:48
Kevin, There is a rule of thumb for diesel engines , if it needs to have the ridge cut ,you need a new liner. Now if you insist on using the liner, you need to use a rigid hone such as a sunnen or similar because a dingle berry hone does nothing for truing the cylinder and being you have a ridge you have an out of round cylinder.It is somewhat of a waste of time and money to put new rings in an out of round cyl. If you get a rigid hone , leave the ridge in the cylinder , this will keep you from ruining a set of stones on the hone as the ridge will dress the upper end of the stones as you hone and keep you from making a funnel shaped cyl. Keep honing untill you get rid of the eyebrow and you will have a round and straight cyl,but there is a good chance you will be over the worn limits, which is why the rule of thumb says if the ridge needs to be cut , it needs a liner.
I own an A267D and I build engines for a living ,if you need the rest of the liners send me an email.
george
old
05-13-2008 19:48:19
No ifs, ands or buts about it you need to use a ridge reamer or throw all the money you put into it out the door
Mikeleone
05-13-2008 18:54:31
You can't get the pistons out of the block without cutting the ridge, can you?
Kenneth06
05-13-2008 18:30:26
Cut the ridges if you are reusing the sleeves. If you don"t it could break the rings. New bearings will move the location where the new rings stop causing a problem. The reason not to cut the ring groove on an automotive engine is the top of the cylinder is used to set up a portable boring bar. If you cut the ring groove it usually cuts of center.
Eric in IL
05-13-2008 18:14:37
If it were mine the ridges would have to go bye-bye.
Hoss in Me
05-13-2008 18:06:33
Always ream with new rings,always! Hoss
