Case 400 with American Bosch PSB Injector Pump Timing
B Neal
05-13-2008 17:01:18
This is an early '50s Case 400 deisel; single plunger injector pump. I had to changeout the pump, but now in installing the "new" pump I'm not sure how to correctly time it, and I could be out 180 deg. I have the timing marks on the pump correctly placed. Can anyone advise me please? Thanks
Scott KY
05-13-2008 18:49:01
 Re: Case 400 with American Bosch PSB Injector Pump Timing in reply to B Neal, 05-13-2008 17:01:18
I just got through replacing one on one of my 401's. If you have a service manual it gives good instructions on timing. If you have the # 1 piston on the compression stroke set the timing marks on the crankshaft pulley at the 26 degree mark. Then set the pointer on the pump on the timing mark. I don't have a manual handy but I think these numbers are correct. If you can find a service manual it is a simple job.
