Throw-out bearing installation
INCase
05-13-2008 14:15:09
Does the throw-out bearing need to be pressed on and off of the throw-out yoke/collar? My old one doesn't seem to want to come off the collar. Thanks.
Larry59
05-14-2008 05:13:29
 Re: Throw-out bearing installation in reply to INCase, 05-13-2008 14:15:09
Yes what Doc is saying is correc. I took mine to a tranny shop and they did it for me. Hope if your replacing that bearing. You are putting in a new or rebuilt clutch and pressure plate?? Will say you lots of work down the line. Also check your fly wheel! Might need turn down a bit. Any auto parts place and turn it down for you.
Larry59
05-14-2008 05:14:34
 Re: Throw-out bearing installation in reply to Larry59, 05-14-2008 05:13:29
Type error..ment correct.. shesss lol
Doc Larry
05-13-2008 15:54:58
Yes, on most applications the throwout bearing is pressed on to the collar.
INCase
05-14-2008 06:01:34
 Re: Throw-out bearing installation in reply to Doc Larry, 05-13-2008 15:54:58
Thanks Larry and Doc for the info. I'll probably replace all the seals/bearings/o-rings and take the clutch and flywheel in too. Don't want to split it again if I don't have to. A new clutch will last me a long time for the mowing/spraying/snow-pushing I'll be doing.
