charging a positive ground system
canadian northe
05-13-2008 06:09:30
when charging a positive ground system with a battery charger do you reverse the cables or just charge positive to positive and negative to negative? Thanks in advance,
old
05-13-2008 10:39:09
 Re: charging a positive ground system in reply to canadian northerner, 05-13-2008 06:09:30
Don't let your mind get in the way of this. ALWAYS the same no matter where the battery is + to + and - to -. This is true 100% of the time on every battery out there.
garytomaszewski
05-13-2008 07:47:27
How would you charge the battery if it wasn't in a vehicle? THINK!!! The ground means NOTHING you are charging the battery! Positive to positive and negative to negative.
Eldo case
05-13-2008 06:46:50
+ to + and - to -
