Oil Leakage
John Ludington
05-12-2008 15:10:39
The transmission of my 440 has way too much lube in it and the hydraulic oil does not even register on it's dipstick. Would this be the tranny to torque tube seal causing this ? I drained some of the tranny oil out and it had a red tinge to it like THC oil.Any ideas as to what I should check before I split the tractor to see if the seal is gone. Any suggestions would be most appreciated. Thanks...John
Charles Santhuff
05-13-2008 08:44:29
 Re: Oil Leakage in reply to John Ludington, 05-12-2008 15:10:39
I had the same problem. I took the piston into the Case dealer when I got the seal rings for it and the shop foreman was kind enough to install the rings on the piston for me. They are kind of hard to get on without ruining them.
JGarner
05-12-2008 15:18:24
The seals on the internal hydraulic cylinder located in the differential case are leaking. You will need to remove the seat, drop the draft arms and remove the upper lifting arms from the rock shaft and take the large cover off the differential housing located under the seat. The piston and cylinder are housed in this piece (its heavy!!), seals are still available from Case.
