case sc
russ morgado
05-12-2008 14:36:03
looking for some help-i need to remove the pulley on the front of the crankshaft of a case sc-it's held on by a pin-what is the best way to remove the pin and can the pin be used again? can a bolt be used as a replacement for the pin? this is my 1st resto and i'm starting to have nightmares thanx for any help- uncle ruff
russ morgado
05-12-2008 15:19:10
 Re: case sc in reply to russ morgado, 05-12-2008 14:36:03
thanx for the info-ruff
patsdeere
05-12-2008 14:54:44
Well enjoy your first resto, it will be a large learning curve.
That is a: PIN, 3/8" x 2" type 1 full length taper groove, crankshaft
Getting it out might not be easy (or if you are lucky) it might be. Make sure that you aren't jamming it in further since it has a taper. Unless you mangle it getting it out, I don't see why you can't reuse it.
If you go to:
Link
you can look at the parts manual on line for the beast.
