This is a bad sign...!
Mike Schotte
05-12-2008 06:24:53
You know how you have those recurring dreams that you seem to get stuck in all night long?
Last night- all I dreamed about was what steps I should take to get the motor unstuck on project DC, and where I might look to see what's causing the steering to be stuck/rusted, too.
(this is the '49DC tractor I got from the salvage yard with the Case 2-bottom plow)
third party image
Also in my sleep- I was making a mental inventory of what spare parts I had purchased to date.
I guess this officially means I've been bitten by the tractor bug again. Not good.
If you put "running DC tractor" on my priority list- it would be so far down as to be in the next county! Not really something I should be working on- especially when the SC might be needing more attention. (see my previous mowing post)
-S.
Camboted
05-12-2008 20:44:50
 Re: This is a bad sign...! in reply to Mike Schotte, 05-12-2008 06:24:53
OK, Go ahead and add some marvel oil, magic formula, or whatever, and let it soak. Maybe you'll get lucky, but this is the only 100%, never failed method, courtosy of DC Tom:
1) get an old spark plug, knock off the procelin and braze on a 1/2" pipe nipple, screw on a standard hydralic hose of whatever length you need to reach a tractor with hydraulic power.
2)Remove the valve cover and the rocker arms. If any valves are stuck, try to free them up so that at least the valves for the cylinder you choose to apply pressure to are closed.
3) Remove spark plugs, and find a cylinder with a piston that is higher on the stroke. If the engine is stuck at top dead center this method will not work. Screw in your hose and apply some pressure. It will break loose, but if you push it to the bottom of the stroke it will be all you can do. So, it is best to go a small distance, then see if you can crank it. If not move the hose to an alternate cylinder and push it in the reverse rotation, go back and forth until free.
Camboted
05-13-2008 02:07:29
 Re: This is a bad sign...! in reply to Camboted, 05-12-2008 20:44:50
Mike,
I forgot to mention the steering. We've messed with a bunch of non-running DC's and my guess is that your problem is in steering shaft bearings in the worm gear box. There are two small bearings that the steering wheel shaft turn on. They are adjusted for end play with a bunch of shims under the casting where the steering shaft attaches to the cover. Remove the three bolts and "unscrew" the steering shaft buy turing it out of the box, you can't pull it out. This will allow you to see these bearings, but i've never seen an old DC with good ones. They are probably rusted solid.
Mike Schotte
05-13-2008 05:05:42
 Re: This is a bad sign...! in reply to Camboted, 05-13-2008 02:07:29
Thanks Camboted, thanks caseman-d. There's a lot of battery damage in the area of the steering column, so I'm sure that doesn't help.
Heck, the acid has even eaten the numbers off of the shifter cover.
third party image
I've replaced the steering column on my SC, so I'm familiar with the worm gear. Didn't know about the bearings, though. How do you get them out and where can you get new ones?
Camboted- can you send me your e-mail address? I didn't see a way to contact you through YTMAG.
-Schotte
C. Amick
05-12-2008 09:15:55
I would drain any water out that is in the oil pan and fill the engine crankcase and cylinders with a mixture of Marvel Mystery Oil/kerosene/automatic transmission fluid. Then, put a 5 gallon plastic bucket over the exhaust and dream about it for another month or two. You may also want to check the transmission and rear end for water and add some kind of used oil to them to reduce rusting. As for the steering, I figure the front spindle may be stuck?
Mike Schotte
05-12-2008 09:25:45
 Re: This is a bad sign...! in reply to C. Amick, 05-12-2008 09:15:55
I've drained the crankcase and the oil was O.K. with no water (so I put it back in for now.)
I'm assuming that water got into the stack before I got it and it's stuck from the top end.
Haven't cracked the transmission plug yet.
No ideas on the steering- but it sure is stuck tight.
I will try y'alls soak recipe and load her up next time I'm out there. (I should have done it long ago- I would have had a 2 year soak by now!)
-S.
caseman-d
05-12-2008 20:38:18
 Re: This is a bad sign...! in reply to Mike Schotte, 05-12-2008 09:25:45
Mike,
You might pull the side inspection covers off and look from bottom up you may be able to see how rusty they may be below the pistons. You should be able to pull the pistons down if not rusted to bad. I like to use atf abd a alcohol mixture.
Steering problem could be in the colum. Water can get down and rust things up if it hasn't been greased. Had a LA that way, just ended up putting some extra miscle on it to free it. Amazing how grease will them steer easier.
caseman-d
old
05-12-2008 07:17:02
My self if it where my tractor I would fill the cylinders with tranny fluid, drain the oil out to make sure it has no water in it. Fill the crank case with oil old or new as long as it has no water in it and walk away from it for at least a week. I've had very good luck getting engines to free up doing just that.
