need more h.p. from my dc
johndeereman
05-12-2008 05:13:04
i just pulled sat with my new tires 14.9-38 firestone field and roads. i run out of power all day started in the 5500 class up to the 7500 class. ive got the small pistons 3 7/8 with ratio rockers and the head is shaved as far as i can rpms are set at 1350 anything else i can do to get quick power it has the 5576a head on it?
dboll
05-12-2008 11:32:13
 Re: need more h.p. from my dc in reply to johndeereman, 05-12-2008 05:13:04
4 1/16 m&w domes, berry cam, 1 3/8" carb and 5505 head is good for 53 to 55 hp, I would like to see one in open 7500 that no one can touch, must be smokin some left handed cigarettes! He wouldn't have a prayer in our area, ps- I have been pullin dc's since 87 and I do know how to build them for hp!
John Noname
05-12-2008 09:51:03
The guy that was pulling out west and in the Old Abe magazine some time back had M & W pistons (don't think they are around) and a carb off an 830. Pulled in a 7500 open class and no very many could touch him. Depends on how much $$$$ you want to spend.
garytomaszewski
05-12-2008 07:17:53
The old hot rod dictum was; you can't beat cubic inches when the head was shaved 4 or 4 1/8 pistons should have been added. Also those tires are a mite tall for your gears. Page DCTOM he has had some pretty good luck pulling DCs.
jim heitkemper
05-12-2008 07:09:31
bigger pistons will go in that block ,,,, ,,,always put lucas additive in the oil .. right before going to the sled on a .zenith carb ,open the fuel jet til she starts to burn rich ..... .if they will allow it rev the motor up to 1800 , make sure governor is working properly ,, jim
