Case 411B Hydraulics
FiremanJohn
05-11-2008 17:49:13
I have a little hydraulic leak in an unusual location. I can not see where it is coming from, but when I use the tractor, the bottom of the gas tank is wet with hydraulic. I figured it was the Case-O-Matic line, so I changed it. Still wet after I use the tractor. The only other hydraulic anything in the area is the interlock things, which I know nothing about. Could one of them leak under pressure? Do they have a relief port of some sort? I am stumped.
Larry59
05-11-2008 20:43:11
 Re: Case 411B Hydraulics in reply to FiremanJohn, 05-11-2008 17:49:13
Try checking this site out . Link First site will ask you what country.. click and follow threw each. Then get to parts and pull up diagram of your tractor there. Find that area and see what it is and if there are like parts for it. Hope this helps.
