301 injector pump
comfortking
05-11-2008 15:59:51
I took the injector pump off of an 830, after I lined up the timing marks, to fix an oil leak between the block and the adapter, the pump bolts to. I noticed timing marks on the gear that runs off of the cam and drives the shaft to the pump while I had the shaft out. As there is way top see the timing marks on the cam, I am not sure I placed the gear in the same position. I did put the pump back on the same place it came off and I did not move the engine. Is the timing still right? Thanks
mEl
05-11-2008 16:26:34
 Re: 301 injector pump in reply to comfortking, 05-11-2008 15:59:51
as long as the engine is at the perscribed number of degrees before TDC on compression stroke the marks on the pump drive gear could matter less. Line up the scribe lines on the pump and put er together. The later 70 series did not even have marks on the pump drive gears, just used the method I described.
