CASE 400 PIOLT BEARING
TIMOTHY GREENE
05-11-2008 13:35:01
SHOULD THE PIOLT BEARING ON THE CASE 400 251 GAS BE "LUBED" BEFORE IT IS INSTALLED. I REPLACED THE PIOLT BEARING WITH CASE PART #A28237. THKS ANY INFO WOULD HELP.
Larry59
05-11-2008 20:48:21
 Re: CASE 400 PIOLT BEARING in reply to TIMOTHY GREENE, 05-11-2008 13:35:01
Now what can I say other then the comments are right as they say so far. Guess just letting you know I was here and trying to help. *S
mEl
05-11-2008 16:35:37
The pilot bearing will receive gear lube from the transmission , that is why there is a seal plate and seal on the flywheel mounting bolts.It should be greased to give it initial lube but should be open so lube can get in. mEl
TIMOTHY GREENE
05-14-2008 16:26:47
 Re: CASE 400 PIOLT BEARING in reply to mEl, 05-11-2008 16:35:37
THKS, GREAT INFO
Den N Ms
05-11-2008 14:04:58
Timothy,The bearing should be a sealed on both sides and a prelubed one.
